What should I watch for when I tear down
Evan MacDonald
09-12-2001 12:55:32
I have my TO 35 in shop class, and will be removing the front end and possibly starting at the engine tomorrow. Is there anything that I should watch for that isn't in the manual? I probably have rocker arm issues to deal with, but, is there anything else?
Evan
Evan MacDonald
09-13-2001 12:33:14
 Re: What should I watch for when I tear down in reply to Evan MacDonald, 09-12-2001 12:55:32
Ok, to make things a little clearer, it's a Z134, and it is being torn down for a total re-build, it has at least 12000 hours on it..... I am going to be pulling the engine tomorrow, and, I'll probably start tearing it down Monday. Evan
Bob in CA
09-12-2001 19:57:38
Evan,
If you have the Standard diesel I would put scribe marks on the sleeve inside the injection pump drive. You might also want to put scribe or locator marks on the cam gear and crank gear as a backup for the normal cam timeing procedure.
If you have the Continental Gas engine it is all pretty straight forward.
Evan MacDonald
09-12-2001 13:00:02
My Z134 that is....
B.C.
09-13-2001 09:56:32
 Re: Re: What should I watch for when I tear down in reply to Evan MacDonald, 09-12-2001 13:00:02
If you replace the main bearing inserts, be very very very sure that #3 goes in the correct way. There is an up and a down to that thing, and if you put it in the wrong way you will starve the lube to the rocker arm and you will not like the consequences.
