MF 65's engine type
Mark
10-12-1998 10:45:48
I have MF 65 Multi-Power -63,and I don't know is the engine model Perkins 4.194 or 4.203.There reads "MF 65" on the hood,but in the serial number sign reads "MF 765".Does anyone know what kind my tractors is?
Adrian
11-11-1998 06:38:30
 Re: MF 65's engine type in reply to Mark , 10-12-1998 10:45:48
: I have MF 65 Multi-Power -63,and I don't know is the engine model Perkins 4.194 or 4.203.There reads "MF 65" on the hood,but in the serial number sign reads "MF 765".Does anyone know what kind my tractors is?
**Couple of ideas for you...
Do you have a US-built or a UK-built tractor? It should be possible to tell by appearance. When Massey Harris merged with Ferguson in the early 50s, the new M-H-F range consisted of similar tractors with different tinwork - a form of 'badge engineering'. When the company began its move to world wide operation and introduced the 65 model, it built them using the grill and bonnet design from the Massey Harris 50 in the USA, and shipped the tinwork of the otherwise identical Ferguson 40 to England for use in the 65 there.
**If you have the UK build, that might just be where the 7 in 765 comes from. When Massey Harris set up in Britain in the late 1940s their early products had a 7 prefix to denote where they were built. Example: the M-H 44 tractor was built in Scotland as the 744 (with a Perkins diesel). The UK market leader in combine harvesters was the 726 model.
**If you have a British built 65 it used the Perkins 4.203 diesel engine.
Is this any help?
Bill Brox
10-12-1998 13:22:56
Yes, I am quite sure if it is a diesel.
The 192 engine came only in UK, and it ended summer or fall 1960 if I remember correct.
So, if you have a late 1960 or later UK version MF 65, or any model MF 65 from the US you have the 4.203 engine...
Can't give you any input of the MF 65 or the MF 765 thing.... but more or less the same tractor I think.
Bill
