My 44 was spuing anitfreeze out of the oil plug.
larry rothe
09-04-2001 15:56:35
I went to drain the oil out of the 44 rowcrop I recently purchased and it drained the antifreeze first, what should I look for? Also it was fouling a plug repeatedly before I bought it, could this be a reason? Any help will be usefull, thanks.
new-toy
09-04-2001 20:58:58
 Re: My 44 was spuing anitfreeze out of the oil plug. in reply to larry rothe, 09-04-2001 15:56:35
sounds like a head gasket. tractor running does it have lots of air bubbles in radiator
marlowe
09-04-2001 18:58:27
rich missed one bad o rings on the sleaves
Richard C. Rose
09-04-2001 20:35:41
 Re: Re: My 44 was spuing anitfreeze out of the oil plug. in reply to marlowe, 09-04-2001 18:58:27
Yep! that too
Dicko
Richard C. Rose
09-04-2001 16:12:30
Larry, causes of coolant in the sump are:
Cracked cylinder head
Blown head gasket
Holed cylinder liner or bore
None of which are very savoury, you can sometimes make an educated guess by how far down the water level will drain and also wether it pressurises the cooling system while its running.
Good luck Dicko
