Q's on my MF20D
Tom B.
09-03-2001 11:13:24
My tractor is an MF 20D. I've been told that it is similar to the 135 and dates 70's to early 80's. I have not found a key for the serial number, it is 811031. It is a yellow industrial tractor with power steering. It's original use was as a mower, with turf tires and a 7-reel Ransome mower (mower for sale!).
What does the Top Link do (aside from the obvious)? Is there an adjustment available? How do I control the angle of an implement?
What kind of oil do I use for the transmission/hydraulic pump? Will automotive tranny fluid work?
How should the draft control be set, in relation to the lift control?
On the right heel is a pedal. It operates a shaft into the rear end, near where the brake shaft is. What is it?
On the right side of the transmission case is a position indicator with a means of adjustment. What is this? How should it be used?
Thanks for any help!
margaret kamrowski
04-27-2002 15:44:54
 Re: Q's on my MF20D in reply to Tom B., 09-03-2001 11:13:24
I AM TRYING TO FIND OUT WHAT KIND OF POWER STEERING FLUID MY MASSEY FERGUSON 20D IS TO USE. I HAVE TO CHANGE OR ADD NEW. IT IS MY YELLOW BABY & I WANT TO DO IT RIGHT. THANK YOU FOR YOUR HELP. MARGARET
C. T. in Oklahoma
09-03-2001 13:35:55
I can only help with the pedal on the right heel. It is a differential lock to help you out if you are stuck in a ditch (or stuck anywhere for that matter). Like any vehicle, if one wheel can turn freely, the other doesn't move so this pedal resolves that problem.
TomB
09-04-2001 10:25:48
 Re: Re: Q's on my MF20D in reply to C. T. in Oklahoma, 09-03-2001 13:35:55
Thanks, I got an email from Big Dean. Boy, that guy knows a bunch!
Tom B.
09-03-2001 11:49:15
OK, NOW I'm cruising the site, trying to answer my own questions. On post had mention of the draft/position controls, but I'd like more detail as to the operation and relation of the controls.
What is a "shuttle shift"? More details on my MF20D: It has the 8-spd tranny and an adjustable front axle. There is a valve (shuttle?) controlling the auxillary hydraulic source vs. the 3-pt. lift. I have it looped back to the source (return?) next to the shift lever. This used to run the lift cylinders for the mower.
I gather that the lever next to the dipstick on the right is a "Response Control Lever". I still don't know what that is, or how it's used.
Anybody know where I might find a loader/backhoe to go on this?
