MF I35 STEERING GEARS
WHEEL GOES ROUN
08-31-2001 20:52:08
I HAVE A MF 135 WITH POWER STEERING, NO CYLINDERS ON THE FRONT STEERING LINKAGE, AS ON SOME MFS . MY STEERNIG SECTOR GEARS ARE BROKEN THE FLAT WEAR PLATE IS SHOT, AND THE BEARINGS ARE OUT OF THE WORM STEERING SHAFT, ALSO THERE IS FLUID UNDER PRESSURE IN THE SECTOR GEAR CASE. IS THIS STEERING UNIT WORTH FIXING, OR SHOULD I TRY TO BUY A USED TRANSMISSION TOP WITH ALL OF IT TOGETHER. DOES ANYBODY HAVE ONE FOR SALE?
OR KNOW ABOUT HOW MUCH FOR ME TO FIX?
Ralph
09-01-2001 18:46:55
 Re: MF I35 STEERING GEARS in reply to WHEEL GOES ROUND AND ROUND, 08-31-2001 20:52:08
Have you determined what caused the failure? The rack gear connected to the single steering cylinder usually gets out of time because the four screws that hold the cover usually come loose. This is directly below the battery case. Below this cover is a plate that serves as a bearing for the rack. When these screws became loose, there was to much clearance between the rack and plate which started the chain of failures. This will usually damaged the steering housing. These housing are very expensive, I have not been lucky enough to find a used one. The housings are easy to repair. The cracks and broken sections of the housing are easy to braze using brass. No not use a stick or wire welder. This will only lead to more damage. On the last one I repaired, I brazed the screw holes and re-drilled and tapped the holes. Was able to get all new bearings and seals. Build up the damaged gears using brass. The unit looked to un-repairable, but it turned out great. The oil under pressure in the case is a result of a problem in the steering cylinder or becuase of a failed seal in the valve. Just reseal the valve, and the steering cylinder, seals are easy to obtain. I repaired one in this condition about 3 years ago. Still working today. Owner was very happy. He was told his best option was to used the tractor for parts. Final cost was less than $300.00. Tractor would sell for over $5,000. Find a good welder, build up the damaged gears (braze using brass), file or grind the gear teeth to match, get a shop manual so the timeing of the gears will be correct, install new bearings and seals, and you will be happy. Sounds like alot of trouble, but it's not. Good Luck!! Ralph
WVMark
09-01-2001 18:07:09
Used complete assemblies are rare and will cost about a grand if you find one. I think fixing it will be a little less expensive, but maybe not much. It took me a year to find one for a MF-35, and then the whole outfit cost me $1,200.00
