MF35 size of bush hog
Paul
08-30-2001 11:20:10
I just acquired a 64? MF35 diesel & intend to buy a 5' bush hog. It was suggested that I limit the bush hog to 4'. Opinions welcomed
Terry
08-31-2001 10:11:41
 Re: MF35 size of bush hog in reply to Paul, 08-30-2001 11:20:10
I have a '61 MF35 with a Perkins diesel, and use a 5' bush hog on it. I could probably have gone to a six footer, but felt I would be taxing the tractor unduly. The five footer works very well, and covers the tire tracks. Happy and safe tractoring.
Terry
alexander
08-31-2001 03:38:34
I have a 135 and it will pull a 6 foot with no problem at all.
Wayne
08-30-2001 18:38:37
I have a '66 mf135,which is nearly identical to yours,that has no problem with 5' bush hog.Mine too is diesel.If you have alot of hogging to do you will be disappointed you didn't get the bigger.6' it too big in my opinion.Hope this helps!
Chris mf35
08-30-2001 17:32:58
mine is a 1962 gas. i run a 5 foot on mine with no problems. i don't sharpen blades ever, sharp blade i beleive leave sharp stobs (flat tires) dull blade bust up stobs. if i can push it over i mow it so far 4 inch sumac is my bigest. old bush hog brand has a removeable left side whitch lets rocks etc out. good luck and happy tractoring.
Hammer
08-30-2001 13:29:13
I have experience with a 135 and used a 5' bush hog. There were times I was cutting heavy stuff and the tractor bogged down, but using a lower gear and/or cutting less (raising cutter) worked fine.
C. T. in Oklahoma
08-30-2001 13:18:11
I have a 1964 3 cyl Perkins diesel FE35 with a five foot brush hog. I don't work it real hard, but it doesn't seem to be too much. I mow several acres.
garvas
08-30-2001 12:20:59
I have a MF35 gas about the same year model as you have and run a 5 foot brush hog all the time. I cut open range land and have never had any problems. You can always limit the size you are mowing. I usually run in 2nd high or 1st high depending on the height of the grass. Cut cedars, mesquite up too about 2" in thickness. Keep the blades sharp and check u-joints and oil in brush hog religously...
Phil in MS
08-30-2001 11:39:57
From my limited experience with the MF 35, I would believe it would handle a 5' bush hog very well! If your buying a used one, get a new set of blades and keep them sharp! This will help your tractor and bush hog do a better job.
If you should get into some heavy growth and you feel that five foot is over loading your tractor, simple take 2/3s or a 1/2 cut until you get into lighter growth!
