Mf 40 steering problem
carl grey
08-25-2001 19:49:48
i purchased a mf 40 industrial tractor that has a steering problem, it is leaking out under dash and therefore low on fluid, i filled pump with fluid but still hard to steer, i think i need to get air out of system how do you do it? also any ideas on leak coming from dash under steering wheel? when were these tracors mfg and where is serial # thanks
Richard C. Rose
08-25-2001 20:30:00
 Re: mf 40 steering problem in reply to carl grey, 08-25-2001 19:49:48
Carl, a power steering system is self bleeding your OK there. But the leak is most probably from the control valve on the column under the dash. It could be as simple as a lose pipe fitting. There to you may find the problem with the hard steer, the adjustment of that valves linkage must be just right, it is common for worn link pins there to reduce or even eliminate the power steer effect.
Good luck
Dicko
