MF 65 LP hydraulic leak question
hotFusion
08-25-2001 15:36:27
I inherited a Massey-Ferguson 65 Liquid Propane tractor from my Grandfather who was pretty proficient about mechanical things. It has a front blade that was added after market and a Brush Hog. At the moment I have a three-prong hay stinger in place of the Brush Hog and it works pretty good, all of the consumables are kept in check, but I've noticed that when I have a Half-ton Round bail on the Stinger that hydraulic fluid leaks out around the hydraulic selector switch (You'll have to forgive my names, I don't know that much about tractors) that allows you to select which to raise (the blade or the stinger on the rear). It doesn't squirt or anything, I was just wondering if it is something I should worry about, aside from keeping an eye on the hydraulic fluid level? Thanks.
Richard C. Rose
08-25-2001 20:39:09
 Re: MF 65 LP hydraulic leak question in reply to hotFusion, 08-25-2001 15:36:27
That sound like 'O'rings on your auxillary hydraulic valve, they harden with age (not like us) its not serious and easy to replace so worth doing to keep things nice & tidy. Regards
Dicko
