M.F.65 3ph problem
julius from ny
08-24-2001 21:06:05
My 3ph doesn't work well after it's been run awhile (will lift the bushhog fine when you first start out)then as you make a few passes it will not lift all the way up BUT will lift a foot or so.The fliuds are full & clean i have but new rings in the lift cylinder.I do have a manaul that shows the system & the adjustments just not sure wich one to make.THANKS FOR ANY HELP JULIUS
Big Dean
08-26-2001 06:13:39
 Re: M.F.65 3ph problem in reply to julius from ny, 08-24-2001 21:06:05
Sounds like your pump needs to be rebuilt Email me if you need help with it
