Convert from LPG to gasoline
Jerry Deaver
08-21-2001 03:57:30
I'm trying to convert a MF65,1960, from factory LPG to gasoline and I'm having heck. Put on a TSX,I think 605 carb. Runs fine with choke fully closed but thats the only way. It has a Continetal engine on it. Could anybody out there give me any ideas on what to do. Need this tractor here on the ranch to drag a fence waygon, if I don't get it going I'm going to be picking up cans on the Highways.
Tyler(WA)
08-21-2001 10:23:22
 Re: Convert from LPG to gasoline in reply to Jerry Deaver, 08-21-2001 03:57:30
I think Mike is on to the problem. It sounds like the carb. you have either has a plugged idle circuit or not enough idle circuit delivery in it's current design for your tractor.
If that's not the case, I'd start looking for leaks in your intake manifold.
Mike In KC
08-21-2001 08:16:09
I have a MF 65 Tractor. It has the continental Z176 engine.You indicated that you have installed a TSX 605 Carb. I believe the correct carb would be a TSX 695. If you use this carb you should be able to get it to run correctly. If you need the carb settings let me know and I will look in my service book.
Hope this helps you out.
Mike In KC
