What size Battery for a MF 165??????
Rob Ellis
08-20-2001 08:20:35
What size battery does the MF 165 Gas Model Call for? I believe the one I have isn't large enough, as it runs the starter slower than if I hook a jumper up to another "fresh" battery. Thanks all opinions appriciated.
Ray,IN
08-21-2001 20:25:06
 Re: What size Battery for a MF 165?????? in reply to Rob Ellis, 08-20-2001 08:20:35
Are both of the batteries you mention the same size? Perhaps you should clean all the connections, particlularly the ground. Some tractors attach the ground to a sheet metal part, and where that part attaches there is rust,paint dirt and loose bolts. I took a hint from my old Case 801B and attached the ground cable to a starter mounting bolt to bypass such a condition. A tractor service battery will give better service too. The automotive batteries will vibrate the plates loose and reduce the output when used in a tractor, combine, etc. That's my thoughts on the matter. I have a MF165 diesel and a 750CCA tractor battery has worked well year-round, I've not had to use a booster just plug it in when under 40 deg. F. for 2hrs prior to use.
bill b
08-20-2001 19:02:43
Hi, I've been using the 1000cca 27 type batteries. They run $69.00-$79.00. Bill
