Rear drawbar won't go down
John Guedel
08-17-2001 08:40:26
I was looking at buying a Massey 65 and the rear drawbars would go up fine but would not go down while the engine was running. Once the engine was shut off the drawbars went down slowly. Any idea what this may be?
smokey
08-18-2001 01:58:55
 Re: Rear drawbar won't go down in reply to John Guedel, 08-17-2001 08:40:26
Move the response lever on the right side just below the seat. If tractor has been sitting for a long period of time things get a bit sticky. Change trans oil - 30 ltrs or so and replace with recommended oil - shell rimula D40 or Shell Agro oil.
If tractor is not a multi power unit then it should probably be easy to fix.
Try Link Massey Furgusen tecnical tips for further info.
