Aftermarket Rims for Massey-Harris Tractors
Mick
08-13-2001 13:18:44
The rear rims on my 44 Special are rotted. The
cast disc centers fine, but finding steel rims
to replace mine are difficult. That wide centered
shoulder makes for a 34" opening about 2 3/4" W.
I want 14"x38" steel rims for 15.5-38 tires. I heard that there is an aftermarket maker for these rims, under two hundred each. Please advise
me where I can purchase correct size rims at a
reasonable price. I ask, where? Thank you.
BlueLite
08-17-2001 16:48:47
 Re: Aftermarket Rims for Massey-Harris Tractors in reply to Mick, 08-13-2001 13:18:44
Worse comes to worse, you can order a jobber rim to fit to basic size and weld in your own supports. That's what I was prepared to do with my 30 regular before I was able to find a pair in decent shape. The calcium is what creates the scarcity I think. I don't know how yours are made but mine as a "V" pinch shoulder for the bolts to crimp down on, and the jobber has "omega" type attachments similar to ford bolt attachments. I would have cut the attachments off with
a cutoff disk and simply welded to the rim an angle iron in circular shape. This is not a real
big job as things goes but it's critical that you
make good welds for obvious reasons.
Ray,IN
08-13-2001 21:19:20
One of the YT supporters is Miller Tire Co. They list new rims and tires of sizes to fit most old tractors. Look to the parts suppliers listed here.
