Lucas changeover
Jeff Murray
10-05-1998 15:27:31
Does the Delco distributor and starter bolt in place of the Lucas equipment on a TE 20 tractor? I have alot of trouble with the starter bendix and can not locate new ones. I would like to replace the entire starter with something more reliable. Any sugestions?
M. Smith
10-06-1998 04:31:44
 Re: Lucas changeover in reply to Jeff Murray, 10-05-1998 15:27:31
: Does the Delco distributor and starter bolt in place of the Lucas equipment on a TE 20 tractor? I have alot of trouble with the starter bendix and can not locate new ones. I would like to replace the entire starter with something more reliable. Any sugestions?
There is no problem with changing the distributor, but to change the starter from Lucas to Delco, you also have to change flywheels.The ring gear on the flywheel is on the front side of the flywhhel for one starter and it is on the back side of the flywheel for the other.
Bob
10-07-1998 16:18:36
 Re: Re: Lucas changeover in reply to M. Smith, 10-06-1998 04:31:44
: : Does the Delco distributor and starter bolt in place of the Lucas equipment on a TE 20 tractor? I have alot of trouble with the starter bendix and can not locate new ones. I would like to replace the entire starter with something more reliable. Any sugestions?
: There is no problem with changing the distributor, but to change the starter from Lucas to Delco, you also have to change flywheels.The ring gear on the flywheel is on the front side of the flywhhel for one starter and it is on the back side of the flywheel for the other.
Try contacting Jack Wetmore in B.C. He has sources for British parts. [email protected]..
Bob
Paul Rauch
10-09-1998 05:45:47
 Re: Re: Re: Lucas changeover in reply to Bob, 10-07-1998 16:18:36
: : : Does the Delco distributor and starter bolt in place of the Lucas equipment on a TE 20 tractor? I have alot of trouble with the starter bendix and can not locate new ones. I would like to replace the entire starter with something more reliable. Any sugestions?
: : There is no problem with changing the distributor, but to change the starter from Lucas to Delco, you also have to change flywheels.The ring gear on the flywheel is on the front side of the flywhhel for one starter and it is on the back side of the flywheel for the other.
: : Try contacting Jack Wetmore in B.C. He has sources for British parts. [email protected]..
: Bob
I have a tractor with a Lucas distributor. I can't get the miss out of it. Is that why people change the distributor?
Bill Brox
10-12-1998 13:30:54
 Re: Re: Re: Re: Lucas changeover in reply to Paul Rauch, 10-09-1998 05:45:47
Are you all absolutely sure that the Delco parts fits on a UK Standard engine on a TEA 20 ?
It is no problem finding all ignition parts, and starter parts for the Standard engine.
Bill
