MF3165 Hard to shift
David Walker
10-05-1998 15:22:59
Recently inherited a MF3165 With a perkins diesel. The clutch is very hard to disengage. Tried adjusting the external linkage but the problem persists. The only way to get into gear is put the hi low in neutral, select a gear and then push then force the high low in
There looks to be an inspection plate (4 bolt) under the clutch housing.
Can I adjust at this point or do I have to split the tractor???
M. Smith
10-06-1998 04:39:02
 Re: MF3165 Hard to shift in reply to David Walker, 10-05-1998 15:22:59
: Recently inherited a MF3165 With a perkins diesel. : The clutch is very hard to disengage. Tried adjusting the external : linkage but the problem persists. The only way to get into gear is put the hi low in neutral, select a gear and then push then force the high low in
: There looks to be an inspection plate (4 bolt) under the clutch housing.
: Can I adjust at this point or do I have to split the tractor???
Has the tractor been sitting for a long period of time? If it has you may have a stuck clutch, if not it may have rolled the lining on the clutch, or the pressure plate may have a broke finger, missing pin or broken ear where the linkage from the finger fastens to the plate.Most likely you will need to split the tractor to repair. The only adjustment thru the acess hole on bottom is the adjustment for the PTO clutch.
Bill
10-06-1998 16:24:40
 Re: Re: MF3165 Hard to shift in reply to M. Smith, 10-06-1998 04:39:02
: : Recently inherited a MF3165 With a perkins diesel. : : The clutch is very hard to disengage. Tried adjusting the external : : linkage but the problem persists. The only way to get into gear is put the hi low in neutral, select a gear and then push then force the high low in
: : There looks to be an inspection plate (4 bolt) under the clutch housing.
: : Can I adjust at this point or do I have to split the tractor???
: Has the tractor been sitting for a long period of time? If it has you may have a stuck clutch, if not it may have rolled the lining on the clutch, or the pressure plate may have a broke finger, missing pin or broken ear where the linkage from the finger fastens to the plate.Most likely you will need to split the tractor to repair. The only adjustment thru the acess hole on bottom is the adjustment for the PTO clutch.
I also have a 3165 and it to is hard to shift. I want to put a pto on it and inquired at a local dealer and was told I needed to install a clutch. Mr. M.Smith, you mention a pto clutch on this machine, do you know what is involved in installing a pto? Is it worth it? Thank you.
