MF 230 injector pump
Mike
08-09-2001 01:12:31
I have a leak where the throttle rod connects to the top of the injector pump. It has a drip that has gotten worse. If I don't start it for a week or so, the fuel seems to lose its prime. I have to pull it to start it. Once it starts, it runs great. Do I need to rebuild the pump or is there an o-ring or seal to be replaced? HELP!!!!!
Big Dean
08-09-2001 04:21:11
 Re: MF 230 injector pump in reply to Mike, 08-09-2001 01:12:31
There is an O-ring on that shaft. If you change it you usually have to have a new gasket for the top. Be very careful when tightening the nuts holding top they twist off very easy. Be sure to get the spring hooked back in the same holes & the inside stop lever pin in the notch in the flat rod run back to metering valve.
