Massey 44
GEB
08-08-2001 06:28:28
How much stroke and bore can you get from the 44 four cylinder engine and also the six cylinder engine in the 44-6? Also does anyone know the length of the connecting rods in each of these engines? Thanx for any Help!
Jake
08-10-2001 04:38:29
 Re: Massey 44 in reply to GEB, 08-08-2001 06:28:28
I believe that 4 5/8 is about the biggest bore you can get out of the 4 cylinder without getting creative with your machining. As you probably know, the bores are not evenly spaced in the block so this causes problems when you try to get too big. 6 1/2 inch stroke is also possible without too many problems. This combination would give you around 436 CID. I know that there are +500 CID units out there, but I don't know how they get to that point. As far as the six goes, I don't know if anyone has really fooled with one because they are so small to start with. My guess is that around 300 cid would be about it.
Gary Herrell
08-15-2001 11:38:06
 Re: Re: Massey 44 in reply to Jake, 08-10-2001 04:38:29
GEB/Jake -
Bores up to 5 inch are possible. Strokes up to 7.5 are possible with custom rods and no deck plate. Deck plate is recommeded for 7.5 inch stroke due to rod length/piston pin height limits. This combination will produce 589 cubes. Jake is right on with the 6.5 stroke for stock rods, but requires machining of rods and cam to fit. 4.625 is possible to bore "on center" (without offset), but would recommend 4.5 bores "on center."
Regards,
Masseypuller
Gary Herrell
08-15-2001 11:41:55
 Re: Re: Re: Massey 44 in reply to Gary Herrell, 08-15-2001 11:38:06
GEB/Jake -
The info I gave is for the 4 cylinder (H260) engines. The stock rod length for these is 9.5 inches. I have a Continental F226 (44-6) engine disassembled, but have not measured the rods up, yet. If you have other questions, please email me.
Regards,
Masseypuller
