MF 85 ('60)Hydro Lift failure
Mike
10-05-1998 08:58:36
Wondered if anyone has information on 3 point lift
failure that was immediate. All I did was exchange the 3 spool external valve that controlled the 3 point and two remote cylinders for a transfer plate.
When starting the tractor, for the first time after
the plate was installed, the lift rose and stayed
up. The side levers had no effect on raising or
lowering. Now the 3 point lift does not work at all.
I hate to split this tractor again (yes, just rebuilt
the PTO clutch). Also, I'm seeing posted that some
are recommending Mult-Weight motor oil for transmission
and hydro oil. I'm using Permatran III; is this
correct oil for this tractor? Any information is greatly
appreciated. Thanks.
and
