Tractor Fire
Keith W.
08-02-2001 10:22:40
Was brush-hogging with my gas MF135 the other day and the tractor caught fire under the hood in a big way, had to bail off the back after grabbing the ignition key. Flames shot up to about 15 feet. I figure that somehow the gas line ruptured or the sediment bowl cracked, or something. Burned for about 10 minutes before the fire dept got there and put it out. Burned up the wires, hoses, left front tire, seat, dash, steering wheel and plenty of paint. Taking it for an estimate now, but was wondering if there are any specific things I should be aware of or concerned about. Didn't appear to damage anything internally, the oil still looked good, shifted OK, etc.
smokey1
08-02-2001 16:42:55
 Re: Tractor Fire in reply to Keith W., 08-02-2001 10:22:40
You may find the parts listings and diagrams at -
Link
After my fire I bought another MF135 diesal. Its fuel tank was rusty so I cleaned the burnt one with Kero fitted a new tap and used it. The black carbon kept glogging the mesh filter above the glass fuel bowl for the next half dozen fills of fuel before it was ok.
smokey1
08-02-2001 16:26:17
Did the fire dept use water or just dry powder?
If water was used on hot metal it has probably got into a few places you wish it hadn't. I lost a MF135 to a very hot fire in 1997. Still borrow bits off it and intend to restore it some time. Fortunately the fire brigade was to busy trying to save houses to worry about cooling the MF135 so oil had a real bad burnt smell but no H2O added. If the unit was insured it will probably be a write off. If the tyres are burnt away and it was hot enough to melt castings like mine then it is better to start looking for another machine.
