Massey-Harris 22
J.D,
07-30-2001 18:51:09
Can anyone help me determine what I have and what year it is? It's a Massey-Harris Mod."22" with the following Ser.#22-OR9066,Thanks for any info!!!
Alan
07-30-2001 21:47:36
 Re: Massey-Harris 22 in reply to J.D,, 07-30-2001 18:51:09
I pull a 46 model 81. It's the original smaller
MH. The lowest I can get into with my 190lbs is
the 3000 lb class but I always did a little better
in the 3500. Of course mine has 28" rubber and
yours prob has the 32 or 34's. Dad has one with
the original 34" tires and a very used motor... he
pulled once (in 3500 lb I think) but the tires are
to big for the motor. Dad pulled my 81 in a 2750
class one time (he's about 30 lbs less) and took
2nd out of 20 or more. MH listed dry shipping
weight on the 22 as 2840 (rc or std?) the 22 has
hydraulics & parts to add weight. Prob gonna start
out in the 3500 classes.
Good luck & e-mail any questions - ALAN
Alberta Mike
07-30-2001 20:16:14
Are you sure it's OR and not GR? The G would stand for gas and the R for rowcrop. In any case your number shows up as a 1951 model. The 1951's started with 7624 and the 52's with 10137 so it's in the '51 year according to my book. Now, if it is an OR, maybe they made an orchard version (which might explain the O) but somehow I doubt it, you'd know if you had an orchard model, lots of streamlined tinwork, etc.
JD
07-30-2001 20:54:04
 Re: Re: Massey-Harris 22 in reply to Alberta Mike, 07-30-2001 20:16:14
Thanks for the reply A.M. It does not have any orchard tin work, but there is a slim chance it was removed. I will have to double check the ser.# Would you have a good idea what the value is? As I am putting it on Auction Sept,8 and have had numerous estimates. It has a factory wide front, hyd., 3pt.,and pto. The paint is original and good. The tin is very straight.
