Is it a TO-20 or TO-30?
OldKyJim
10-01-1998 19:24:44
I just bought a Ferguson tractor; the owner said its a TO-30. However, the serial number plate on the dash is missing, so I don't have that information to help me ID this my Fergie with any certainty.
Before I plunk down my hard-earned cash on manuals for it, can anyone provide some easy-to-spot differences between the TO-20 & the 30? It doesn't matter much to me which I have, as I got a good deal on what appears to be a solid machine.
An old timer at work was telling me the TO-30 had a gear-shift starter setup; my tractor has what appears to be an "S" in the top righthand position of the shift pattern on the transmission cover. Is he remembering correctly, or did the TO-20 have the same arrangement?
Thanks for any help.
Jim
M. Smith
10-01-1998 19:51:49
 Re: Is it a TO-20 or TO-30? in reply to OldKyJim, 10-01-1998 19:24:44
TO-20 had the oil filter in the bottom pan accessable thru a plate on the bottom of the pan . TO-30 had the oil filter on the side of the block.
: I just bought a Ferguson tractor; the owner said its a TO-30. However, the serial number plate on the dash is missing, so I don't have that information to help me ID this my Fergie with any certainty.
: Before I plunk down my hard-earned cash on manuals for it, can anyone provide some easy-to-spot differences between the TO-20 & the 30? It doesn't matter much to me which I have, as I got a good deal on what appears to be a solid machine.
: An old timer at work was telling me the TO-30 had a gear-shift starter setup; my tractor has what appears to be an "S" in the top righthand position of the shift pattern on the transmission cover. Is he remembering correctly, or did the TO-20 have the same arrangement?
: Thanks for any help.
: Jim
Rob
10-02-1998 18:04:24
 Re: Re: Is it a TO-20 or TO-30? in reply to M. Smith, 10-01-1998 19:51:49
Jim, the To-20 and even later Tea models all have the start position in shift pattern. check the casting number on the engine block. the 20 has z-120 cast on the side the 30 has z-129. the filter on the side is also a giveaway for the 30 as mentioned. If youve driven both its easy to tell the power difference of the 30.
Rob
OldKyJim
10-02-1998 20:16:35
 Re: Re: Re: Is it a TO-20 or TO-30? in reply to Rob, 10-02-1998 18:04:24
Thanks for the info; that confirms mine is a TO-30. Now to order those manuals!
jim
