Hydraulic leak
Lavaughn
07-23-2001 10:05:08
I have 1960's model MF 135. There is a hydraulic leak on the left side of the rear axle center housing at the hydraulic pump positioning dowel pin access point (a small oval plate held in position by two studs with nuts). Does anyone know if I can remove this plate and replace the gasket without the pump moving? Someone has told me that the pump would not move if I only removed the plates on either side ONE AT A TIME. Also is the dowel pin affixed to the plate or does th3 plate merely hold the dowel pin in place? Thanks in advance for any help.
wayne
07-23-2001 19:11:31
 Re: Hydraulic leak in reply to Lavaughn, 07-23-2001 10:05:08
I would like to know about this as well! Mine does not leak (pour)however it does look moist around these plates after working.I have '66 MF135.
Jack in NB
07-25-2001 05:39:52
 Re: Re: Hydraulic leak in reply to wayne , 07-23-2001 19:11:31
Gentlemen -
The dowel is originally welded to the plate. It often comes loose, but can't fall out.
We use silicone bathtub caulking for gasket material - for most of the transmission gaskets.
The surface has to be clean and dry, but works better than gaskets for controlling leaks.
You may have a problem with oil leakage on these plates, preventing the use of silicone without draining the trans and diff.
It's nice to have a spotless tractor, but I've kindof resigned myself to accepting some seepage everywhere as long as it doesn't drip.
Have fun, guys!
Jack
wayne
07-25-2001 19:32:30
 Re: Re: Re: Hydraulic leak in reply to Jack in NB, 07-25-2001 05:39:52
Thanks Jack and Big Dean for response.I am not too worried about mine at this time because I use my tractor for working!Just wanted to be able to take care of it if becomes worse.
