Jack in NB, Hydraulics MF 165
Rich G
07-20-2001 18:02:49
Jack thanks for the previous info. I purchased the MF165 repair manual but it doesn't show where the hydraulic pump filter is. Please help!!!!
Thanks
Jack in NB
07-25-2001 05:47:46
 Re: Jack in NB, Hydraulics MF 165 in reply to Rich G, 07-20-2001 18:02:49
Hello.
Been "off the air" for a week or so. Hydraulic filter should be accessible through the left side cover, the one which has the PTO shift lever through it.
Ours is accessible, but I understand some with more fancy internals may have plumbing in the way.
Be sure to re-safety the hold-down cover - wire to prevent it from unscrewing. I'm told the cover and filter give the pump some very expensive indigestion problems when they get chewed up and sucked in.
Richg
07-26-2001 04:25:39
 Re: Re: Jack in NB, Hydraulics MF 165 in reply to Jack in NB, 07-25-2001 05:47:46
I had to pull the top off to get to the filter. The filter had about a half and inch of sludge down at the bottom and the the rest of the filter was pretty nasty. I hopt that was the problem. The filter was pretty expensive. I will hopefully have it back together by next week, that is if I can put it back together right!!!!! !!!!! Thanks Jack in NB
smokey1
07-22-2001 20:48:42
Go to>Link
tecnical>Link tips MF hydraulic - one of the best descriptions I have seen. also>Link
I think you need to lift the top off the gear box
- a bit of a mongeral of a job.
