Mf50 dead cylinder
eddie
07-18-2001 19:17:33
my mf 50 has a dead cilinder, except under a load. when the thing starts to work under a load, it smooths out and runs great. i have checked compression, the highest and lowest are 7 lbs apart. all plugs look good, light tan color. have good spark at all times.i dont have a leak-down tester to check blow by but it doesnt smoke hardly any.any suggestions????? and the governor works smooth, and its always the #3 cylinder
Defiant
07-20-2001 11:02:57
 Re: mf50 dead cylinder in reply to eddie, 07-18-2001 19:17:33
Have you checked the gaskets, i once had the same happen to me and it was because the exaust had become lose on the gasket, however it never bucked up with a load, but try it anyways, try it anyways and tell us how you did ;-) laters, Defiant
Ken McWilliams
07-20-2001 09:32:21
Eddie,
You may have either a defective spark plug or wiring.
Allow it to miss for a while and remove the plugs to see which has the most soot. Then move that plug to another cylinder, run for a while and if it misses check it again. If the soot is the same cylinder, then start checking the wiring adn distributor cap. If the same plug is sooty, replace it.
Another way to find which one is to start the engine while cold and feel the exhaust runners on the manifold or feel the sparkplug bases. The one that is the coolest is the one giving the problem.
Sometimes these engines don't run spark plugs with hot enough range. A gasoline tractor engine typically has about 7:1 compression and 2500 RPM full speed. Hotter range sparkplugs often helps.
I've had several Ford "N"s that ran kinda lousy. Everything was in spec, but just would be hard to start and not run smooth. I changed to a range hotter than the specification and the problems went away.
It was the opposite when I was racing cars. A hot range sparkplug would cause pre-ignition on an engine with 11:1 compression. I would have to run a lower heat range than a street engine.
Ken McWilliams
Dayton, OH
