Easy answer for starter problem on TE20?
Mike in Fla
04-22-1998 14:40:46
I have a '48 TE20 which has set up for 25 years. The shop wants $155.00 to fix the starter. All the guts need replacing. Will an 8N starter replace it? Anyone with an extra starter laying around (haha)?
Give me some (cheap) ideas please,
Mike
Tad McGrew
04-23-1998 07:17:39
 Re: Easy answer for starter problem on TE20? in reply to Mike in Fla, 04-22-1998 14:40:46
I have a 48 TE 20 myself. I had my starter done for $60. Must not have been in bad shape. There is an alternative for you. The TO 20 had a Delco starter that is interchangeable. I don't have the part number right now but I can get it for you if you'd like. I'll look for a follow-up.
clair
12-25-1998 10:32:04
 Re: Re: Easy answer for starter problem on TE20? in reply to Tad McGrew, 04-23-1998 07:17:39
:We have been having a hard time finding a delco that would match up withare te-20. we have a lucus starter short through, we need a part number for a delco short though.
Bill Brox
04-22-1998 15:19:32
Hello
TE 20 starters may be around, depend on which engine you have. Price $194 I think brand new. Parts also available, bushings, brushes, and bendix.
This is in Norway, I also think you can find this in England at the 20 parts company, but don't expect them to be cheaper.
Unfortunately I have prices for the parts, but they can't cost much.
Are you able to fix it yourself if you had the parts, unless the field and rotor is damaged ?
Pleas let us know.
: I have a '48 TE20 which has set up for 25 years. The shop wants $155.00 to fix the starter. All the guts need replacing. Will an 8N starter replace it? Anyone with an extra starter laying around (haha)?
: Give me some (cheap) ideas please,
: Mike
Mike in Fla
04-24-1998 19:47:34
 Re: Re: Easy answer for starter problem on TE20? in reply to Bill Brox, 04-22-1998 15:19:32
Hey, this is Mike again. Thanks for the replies. I thought about rebuilding the starter myself, but the machine shop said the insulation in the field coils will quickly break down during use. And the rotor or something needs rewiring. This is a reputable shop and I guess they are being truthful. I will look into getting the Delco starter. If you don't mind, Tad, please send me the number. If that doesn't work, I'll just pay the bill. I want a reliable tractor when I'm done, not a patch job. In 40 years, that extra money won't matter much, but 40 minutes time now might save it!
Thanks,
Mike
Stan Hall
04-30-1998 16:27:20
 Re: Re: Re: Easy answer for starter problem on TE20? in reply to Mike in Fla, 04-24-1998 19:47:34
: Hey, this is Mike again. Thanks for the replies. I thought about rebuilding the starter myself, but the machine shop said the insulation in the field coils will quickly break down during use. And the rotor or something needs rewiring. This is a reputable shop and I guess they are being truthful. I will look into getting the Delco starter. If you don't mind, Tad, please send me the number. If that doesn't work, I'll just pay the bill. I want a reliable tractor when I'm done, not a patch job. In 40 years, that extra money won't matter much, but 40 minutes time now might save it!
: Thanks,
: Mike
