Leak on super 90
vere
07-15-2001 11:56:23
I have a super 90, that I was mowing with yesrerday, and when I got finished and I noticed that the power steering was leaking in the front of the tractor. I took off the grills, and looked, but I cant see where its leaking, its all dry in there, its, (running), out under where the tie rods connect to the power steering system. I have a book, and it looks like there is an oil seal on the steering shaft that might be the problem, my question is if thats it, you have to take out the shaft to fix it, does the whole steering system have to be removed to do that, or can you fix it without taking the whole thing out? I guess Big Dean might be the one I need to ask, I'm not sure. thanks for any help
Jeff
07-16-2001 05:43:29
 Re: leak on super 90 in reply to vere, 07-15-2001 11:56:23
I have a MF85 which is almost identical to your 90. I had the same exact leak & I had to pull the whole steering assembly out to replace the seal. The way it is designed you cannot replace it from the bottom. If you do not have a Shop manual for you tractor I could email you some pictures of it & the procedures to remove it.
Jeff
