MF 65 parts swap with ?
Johnny
07-11-2001 20:20:55
I have a MF 65 with an excellent motor, Perkins 4 cyl. diesel, the problem is that the rest of this tractor is flat wore out, I mean both clutches are gone, the 3 pt. hitch leaks bad,numerous seals leaking, the hydraulics are shot, tires are bad ,etc. I would like to swap the motor to a newer model tractor,we have several salvage tractor auctions nearby. What later model tractor would accept this motor? possibly a 165 or maybe a 230 something or what, thanks for the help. Johnny in E.Tx.
PeteTatham
07-11-2001 23:43:41
 Re: MF 65 parts swap with ? in reply to Johnny, 07-11-2001 20:20:55
Johnny, Swapping the motor (if you can) is the easy way out. Just roll up your sleeves, open your tool box and get on with a full restoration. It's not that difficult or expensive, and at the end of the day when you've
got a superbly restored tractor you'll be glad you did. There's no greater feeling of satisfaction, (well one maybe), in the world.
Regards,
Pete.
Johnny
07-12-2001 19:31:25
 Re: Re: MF 65 parts swap with ? in reply to PeteTatham, 07-11-2001 23:43:41
My dad bought this tractor in the early 70's and I always hated running it, it was supposed to have power steering but it never worked very well, I parked it 2 years ago hoping it would just go away but it never did, so the other day I put a fresh battery on it and it started right up, what I need is a decent rake tractor and something to pull a tedder with for next season. The parts for a rebuild would run me about 3-4 thousand dollars. I don't want to put that kind of money in this tractor. I mean this old tractor needs everything, a clutch, some 3 pt. arms,tires,a seat,a drawbar, lift pump, power steering pump, and I also need one set of remote hydraulics. I am going to keep my eye open for a later model with a bad motor and try to do the swap. Johnny
Chips
07-18-2001 13:20:33
 Re: Re: Re: MF 65 parts swap with ? in reply to Johnny, 07-12-2001 19:31:25
Sell it to somebody who'll keep it whole. What your talking about is only a little more than a weekend's work. A clutch is only a couple hundred bucks, and unless the pump bodies are busted, those can be rebuilt too. Power steering may just be worn links in the adjustment turnbuckle.
You could pull a tedder or rake with a 9n. That 65 built for sterner stuff!
Johnny
07-19-2001 20:25:41
 Re: Re: Re: Re: MF 65 parts swap with ? in reply to Chips, 07-18-2001 13:20:33
My rake weighs more than a 9n, I ran this tractor through the local auction twice and high bid was $300, they just aren't worth much around here, escpecially one needing as much work as this tractor. I found a MF165 with a rod through the block at junk yard for $850, may go back and get it. Johnny
