TO-35 Old Style Hyd Pump
LP
07-08-2001 18:19:56
I disassembled the hyd pump in my '55 to-35 and was surprised to find the pistons have no rings. The parts book for the early style pump doesn't show any either even though the pistons have grooves. It would seem the the pump would work more efficiently if there were rings.?. Has anyone tried installing rings from the later style pump? My spec book shows the pistons are the some size. Thanks for any advice.
Graham
07-09-2001 09:06:19
 Re: TO-35 Old Style Hyd Pump in reply to LP, 07-08-2001 18:19:56
LP,
If you give me the serial number of your FE35/MF35 I will tell you when it was built. The piston should have rings on their number is 892604M1. They are in stock I have just checked.
Hope this will help.
Ken Lewis
07-31-2001 20:24:25
 Re: Re: TO-35 Old Style Hyd Pump in reply to Graham, 07-09-2001 09:06:19
You can update it to the later pump! I have a 55 model TO-35 and my pump was worn out. I installed the later pump and it works great! No modifications required.
e-mail if you want the part number for the later pump.
KL
