Massey crawler
Peter Hopkins
07-07-2001 11:17:51
Massey crawler with Drott 4 in 1 loader. Where is the serial # located? The owner at first said he thought the machine was an AC model 4425. Comparison with pictures of a Massey 200 indicates it to be a Massey, model unkwown since the hood is different on the 200 but the undercarriage is identical. Any info will be greatly appreciated.
marlowe
07-08-2001 12:22:08
 Re: Massey crawler in reply to Peter Hopkins, 07-07-2001 11:17:51
hay peter massey had two small crawlers with drott loaders they were the 2244 and the 200 the loader was from drott in wausau wi.the crawler was made in canton ohio as far as i know A.C. was not in the picture at all. the ser.no i think is on the rear of the crawler hope this helps
G Williamson
05-22-2002 12:31:43
 Re: Re: Massey crawler in reply to marlowe, 07-08-2001 12:22:08
Peter massey made a 300 drott built in 1968 which also had a ripper or a back hoe most went to africa some worked in the midlands area mine is still going.
Peter Hopkins
07-08-2001 15:40:07
Marlowe, thanks for the response. I'll check it out again. The machine has a tool bar on the back for mounting ripper teeth so the rear is mostly covered with a steel plate. The track rollers don't show any wear but the tracks aren't very flexible, maybe they will loosen up with use. The owner says he has rebuilt the engine (diesel) and the final drives, wants 8000 for it. Don't know if i want it that bad. Thanks again, Peter
marlowe
07-08-2001 19:34:47
 Re: Re: Re: Massey crawler in reply to Peter Hopkins, 07-08-2001 15:40:07
if its a 200 it will have a 3 cyl. perkins a 153 engine i have one and it is a great little cat if the rollers and pins an bushings are real good 8000 is not out of line. rollers, pins,bushings,an sprockets are real hard to find
