MF35 steering wheel removal
Randy
07-07-2001 01:02:29
How do I get my steering wheel off my MF35? I want to replace it because it's all cracked and my wife bought me a new one. I have taken the nut off, soaked the shaft with penetrating oil, but it won't budge, even with a puller. I don't want to ruin the steering shaft. Thanks for the advice in advance.
Randy
07-24-2001 09:33:36
 Re: MF35 steering wheel removal in reply to Randy , 07-07-2001 01:02:29
The bearing puller and penetrating oil did the trick. Thanks, all.
haci yilmaz
07-10-2001 00:21:07
Dear Sir,
We introduce ourselves as GENMOT CRANKSHAFT MANUFACTURING CO. which is
manufacturing crankshaft since 1987. Now we enlarged our manufacturing crankshaft since 1987.Now we enlarged our manufacturing field and established genmot group ltd.
Genmot casting factory, Genmot machining factory and genmot automotive marketing-
trading co. ltd.we have approximately 162 kinds crankshaft in our production line from 1 cyl. to 8 cyl. we sell our products 55% to domain market and export 45% to foreign market such as Italy, Belgium, South Africa, Mexico, Sudan, Greece, Spain, USA, Germany,
England, Danmark, Algeria, Maroc, Irak, France, Iran, China, Hungary, Argentina, Chile....
GENMOT CRANKSHAFT FACTORY Certificated with ISO 9002 certificate from
RWTUW-GERMANY.
However , we export the spare parts of Tractors , Trucks, Cars , Bus and Compressors (air & water)
(piston, cylinder liner, pistonring, gasket, valve, valve guide, valve seat ring, engine mounting, rubber mounting, air brake system, clutch systems, adjustable arm, hydraulic midle tension arm, power steering conversion kits with bypass system, gear pump, tandem gear pump, door rubber, window chanels, trunk lid rubber, glass rubber, stell whell rim, driving lights, headlight, reflector, glasses, suspension parts,chassis - body parts, steel wheel rim, complete radiators ..... ..)
We are ready to serve you about all the spare parts , If you are interested in .
BEST REGARDS
Mr. HACI YILMAZ
www.genmot.com.tr
fax: +90-332-238 57 76 NOTE :AS WE ARE GENMOT BOUGHT THE CRANKSHAFT LINE OF MERCEDES BENZ IN 2001. WE CONTINUE TO PRODUCE VARIOS CRANKSHAFT WITH HIGH QUALITY AND ECONOMICAL PRICES Tractor Groups :
DEUTZ, FIAT, FORD, IHC, JOHN DEERE, MASSEY FERGUSON, STEYR, UTB, ZETOR,
LEYLAND-BMC, MWM.
Trucks Groups :
BEDFORD, BERLIET, CATERPILLAR, CUMMINS, DAF, DAIMLER BENZ,
FIAT-IVECO, FORD, HANOMAG, ISUZU, KAMAZ, LEYLAND-BMC, MAN, PERKINS,
RVI, SCANIA, SAME, VOLVO.
Car Groups :
ALFA ROMEO, AUDI, CITROEN, FIAT, FORD, ISUZU, KIA, LADA, LAND ROVER,
MERCEDES BENZ, MITSUBISHI, NISSAN,OPEL, PEUGEOT, RENAULT.
Other Engines :
DAHL, DEUTZ, HANOMAG, HATZ, JEANBACHER, KNORR-BREMSE, LISTER, LOMBARDINI, PETTER, WESTINGHOUSE..... ...
Laurence Lombard
07-09-2001 10:18:42
I'd be tempted to slit the steering wheel hub down the side with a hacksaw or grinder - not very elegant, but it works with rusty pipe fittings provided you are not sentimental by the item being rendered completely useless.
Just a thought
Laurence
eddie
07-10-2001 19:32:05
 Re: Re: MF35 steering wheel removal in reply to Laurence Lombard, 07-09-2001 10:18:42
i have a massey 50, the way i had to remove my steer wheel was, soak just like you did, but, when usin the puller, ,matco 2 ton gear puller, after i had a good amount of pressure on the shaft from tightening the puller i used a brass hammer and struck the shaftt of the puller fairly hard, this took place about 3 or 4 times but the wheel popped right off fairly quickly
ferrell freeman
07-08-2001 07:11:14
If you know someone with a brake pin puller for S-CAM brakes this will also work to pull this type steering wheel.
Terry
07-07-2001 09:22:32
Randy:
I did pretty much the same thing as Randy did, when I took the steering wheel off my MF35. I kept it under tension (used a Sears pulley puller and nylon rifle sling). She finally POP'd off. Do yourself a favor when you put the new one on, put a coat of anti-seize on the steering wheel shaft and wheel itself. Makes it a much easier to take it back off in the future.
Marty
07-07-2001 07:22:00
Randy i had the same problem with my mf-50 using my home made puller lt looked like it was never going to let go. So i walked away in "digust" leaving it under tension. Two beers later i came back for another go and found the puller on the ground and steering wheel loose.
Try it you never know your luck or at the very least you might enjoy a cold beer!
Good luck Marty.
Jim/Mississippi
07-07-2001 09:46:48
 Re: Re: MF35 steering wheel removal in reply to Marty, 07-07-2001 07:22:00
Marty,
I think, according to a large beer companys
commercial, what you've just described
is a (Cold Wrench)
:-) Laughing out Loud :-)
Pete Tatham
07-07-2001 01:25:33
I've found that the conventional three legged puller wont work in this situation. I recently had to remove the steering wheel from a tractor where the wheel was siezed solid. I found after trying just about everything that a bearing puller did the trick. You should be able to hire one from your local tool hire shop, but even if you have to buy one they're a good investment.
Hope this helps,
Pete.
Steve
07-09-2001 22:30:04
 Re: Re: MF35 steering wheel removal in reply to Pete Tatham, 07-07-2001 01:25:33
After all these years of car and tractor restoration I have found my trusty torch to be my best friend. A little bit of heat goes a long way. I have yet to find a nut or bolt that won't give up to the pressure of heat. I have used the acetaline torch for many a stuck bolt and always have had success. Hope this helps....
