MF 204 Revers-O-Matic
Lyn Bradshaw
07-05-2001 16:47:05
I have a MF 204 with a revers-o-matic transmission. Problem is it won't go in reverse. It seems to want to but just can get there. Anyone know of an easy fix?
Lynn McFadyen
07-17-2002 20:51:45
 Re: MF 204 Revers-O-Matic in reply to Lyn Bradshaw, 07-05-2001 16:47:05
I got the same problem , MF 204 work bull revers-o-matic will not back up- only bought it last winter and did not use till spring -at first it only missed reverse occasionally and would eventually correct with alternate foreward/reverse blips of the shuttle pedal.Now it only moves foreward- I know that I got some water in the 80/90 wt mineral diff/hydr case but cannot find where to check or add to the torque converter that supposedly takes type "A" trans fluid (and what does that change up to?)The I&T MF-14 manual is vague as to this.Also it is hard to find mineral oil here .It was previously GL1 co-op brand oil in Manitoba but long since unavailable and no Massey dealer close. Could you let me know if you found, and what type of fix worked?
