Farmall guy lost in Massey Land
Michael Soldan
07-01-2001 14:02:26
My son-in-law has purchased a Massey30 and it is sitting in a barn. The engine is siezed but that's standard mechanical stuff, it is the one rear wheel that will not turn and we can't budge the tractor...I suspect that a brake is rusted on. Is there another explanation for this siezed wheel? If it is the brake does the rear wheel have to come off in order to get at the drum and lining? Thanks for any help..now if it was a Farmall I'd know what to do...Thanks from a traveller in Massey Land
Alan
07-02-2001 22:20:47
 Re: Farmall guy lost in Massey Land in reply to Michael Soldan, 07-01-2001 14:02:26
Michael Soldan,
Well, at least you're color consistant if not brand
consistant. A step in the right direction, I'm sure.
I'm e-mailing you 3 pics from my 44 book. I don't
own a scanner and a digital camera is not the way
to do this. Let me know if they don't come out
right and I'll photo copy it & send them out.
On Massey's, (correct me if I'm wrong guys) 30's
and up all have a similar braking system. 22, 20,
81 & etc. have disc(s) in the axel housing. If
you have trouble getting them relined, there's a
guy up here that has done several for dad.
Good luck - ALAN
Maybe I'm not lost in Massey Land/Michael Soldan
07-03-2001 19:06:13
 Re: Re: Farmall guy lost in Massey Land in reply to Alan, 07-02-2001 22:20:47
Thanks Alan, sounds like something that could be very useful.....I own 5 Massey Fergusson Ski-Whiz's...does that make me a Massey guy????? ????..maybe I'm not lost in Massey land after All !!! Thanks from Mike in Exeter Ontario
ANDREAS STYLIANIDES
03-14-2002 05:04:21
 Re: Re: Re: Farmall guy lost in Massey Land in reply to Maybe I'm not lost in Massey Land/Michael Soldan, 07-03-2001 19:06:13
AM LOOKING FOR MASSEY FERGUSSON 698 MODEL
TO EXPORT TO CYPRUS
PLEASE IF YOU GOT ANYTHING IN MIND LET ME KNOW
Sounds like another convert to MASSEY
07-04-2001 14:52:20
Mike,
After talking to Dad, he said it's probably bands
around the drum instead of shoes inside. (MORE
LIKE THE 101 THAN THE 44) We don't have a manual
on the 30 yet but I think the basic concept is the
same. Oh, yeah. Dad also wanted me to stress to
you to change the seals even if they don't leak.
He's been burned twice and for $12 a side "it's
cheap insurance" against the old one going bad
because of new usage. Good luck - ALAN
Michael Soldan
07-04-2001 21:35:21
 Re: Re: Re: Re: Farmall guy lost in Massey Land in reply to Sounds like another convert to MASSEY, 07-04-2001 14:52:20
Thanks for the info..greatly appreciated, I hope to get at the tractor next week and get it out of the barn where we can get at it. Mike
Alberta Mike
07-01-2001 21:01:51
Hello Mike, fancy meeting you here. I think those 30's have the same brake system as on my 101 Juniors, just take that side cover plate off the brake assembly on the side of the transmission case and there is a band/drum setup inside. The band expands outwards if I remember correctly and contacts the inside of the drum. It was the same as the brakes on the 44's as well as all 101/102 Junior and Senior models. Good luck and hope it's that simple. I've done both of my Juniors with the wheels still on. You will probably have to take off the floorboards to really get in there, and also all the linkages, shafts, and pedals too I believe. Did I ever send you any of this Massey stuff I've got here? Let me know by regular email.
