MF165 spraying hydr. fluid through standpipe cover
Rick in Ft. Wor
06-29-2001 17:43:39
I took off the cap assembly that fits over the standpipe and bolts to the top plate. After I put it back on it started blowing fluid out the left side when the lift and draft levers are fully up. I've tried torquing it to different degrees and even used liquid gasket to stop the leak but the most success I've had was just to slow it down. Any ideas? Thanks
