What should I look for when buying a 135?
Rainman
06-28-2001 08:07:43
After much searching I have found a '69 MF 135 for sale for $3500. It has a 3-cyl. gas engine and power steering. I have started the tractor and driven it around. It sounds great and drives good. Doesn't smoke at all. I tried all the gears in both hi and lo range. No problems there. The lift and PTO seem to work fine. The only complaint that I have is that the clutch has no (I mean ZERO) play in it. The dealer is supposed to have the mechanic (who happens to be my DAD) adjust that for me. I will be trying it out this weekend doing some bush-hogging with it. What should I look for with this tractor? Are there any other websites that have 135 parts and information or photos? Any help would be appreciated.
TB
06-28-2001 10:49:16
 Re: What should I look for when buying a 135? in reply to Rainman, 06-28-2001 08:07:43
Rainman, It sounds like you can't have a better situation to check out the mechanical condition of the tractor, since your Dad is the mechanic. I own a Massey Ferguson - They are very good tractors and the 135 is one of the best of that era, although I prefer the Perkins diesel. The main thing you need to do is make sure it fits your needs and feels right to you. Watch the oil pressure when it is up to working temp. Make sure your lift works well after the hydraulic oil is heated up and watch the temp. gauge while working it hard. Your Dad should be able to tell you how much life is left in the clutch. GOOD LUCK!
wayne
06-28-2001 20:02:01
 Re: Re: What should I look for when buying a 135? in reply to TB, 06-28-2001 10:49:16
I have a'66 mf135 diesel and I have no problems with bushogging, operation of a 6' tiller attatchment and post hole digger with 12" auger. I have been told by a good local dealer that the gas version is equally good.If this tractor has been taken care of,I'm sure you'll be satisfied ,especially if your dad thinks it mechanically sound.
