Yellow Wheels
Jim.UT
06-26-2001 20:42:13
This is an implement question, but I figure you Massey-Harris restorers will have good insight. I have a MHF 36 hay rake and a MF 124 baler. They both have very faded paint and yellow wheels. The red shouldn't be a problem because I see MF red offered everywhere I go, but the wheels are too faded to get a good color match. I looked at JD yellow, but it's a little too pastel for my taste. What do you use? Would a Caterpillar yellow or safety yellow be closer to the right color? I'm not looking for 100% perfection, just want them looking better than they do.
Also, I have a parts manual for the baler that lists part numbers for the decals. Anyone know if the MF dealers can still get those from the part number? I'd like to find an owners manual and/or a parts manual for the rake, too. Thanks in advance.
K-Mo
06-30-2001 05:56:05
 Re: Yellow Wheels in reply to Jim.UT, 06-26-2001 20:42:13
Jim,
I have researched options to the expensive automotive paints. I have paint mixes from VanSickle Paints for the Massey Harris Straw Yellow. VanSickle paint is available through hardware and farm stores.
The mix is as follows:
1 Quart 454 + 1 Quart 462 TINT F-1, R-9
Box Quarts Together Then Tint
The 454 is International Yellow and 462 is White. Most Vansickle retailers can mix and tint.
Go to>Link
K-Mo>Link
Dave T
06-28-2001 18:22:09
I had a real tough time crossing over the old numbers I found in Keith Oltrogges Massey Data book. Finally my paint guy went into the library back at Pittsburg and found a number to use. This will work for PPG or Ditzler, and can be crossed over to others....it is MBC 3274...the old JD industrial yellow is real close, like ET said, but when I was in the paint store, I had no way of determining which was the old, and which was the new. Neither could the paint guy...This number is called Bright Yellow, but was called Mellow Yellow a few months ago...Who knows what they'll call it next month....
A professional restorer told me that does a lot of Massey harris restorations, that 40% schoolbus yellow, and 60% white will give you the same results...
This is some of the stuff I learned while trying to find the right color match for my 101 Senior
BlueLite
06-27-2001 18:36:18
Any bright sunburst yellow would do. The
darker the less appealing, you want more leaning to very light. As far as red I used
home hardware's fire red and the tractor looks
great. I tried their yellow also but found it too dark and had to repaint it. I've seen people even use schoolbus yellow, very ugly. I also have an old MH #26 2 bottom on rubber I'm going to paint soon.
ET
06-27-2001 09:21:10
I have used the old JD industrial yellow and I think its a close match. Its also easy to get.
Chevy
06-28-2001 04:48:21
 Re: Re: Yellow Wheels in reply to ET, 06-27-2001 09:21:10
TSC Stores carry a colour called Federal Yellow and it is without a doubt the closest match I have found as well they carry Ferguson Red which matches the red.
Mike Leggett
