How to repair shifter to remove looseness and preving sticking?
John Bailey
06-26-2001 20:03:14
I have a MF35 Delux with a very loose shifter. It shifts fine as long as I push down on the shift knob as I shift, but binds and is hard to find the shift gate if I don't push down.
Can this be repaired by removing shift lever from the top by removing a pin? It might come apart, but can I get it together without further disassembly? I hear of someone welding up the ball on the bottom of the shift lever, but how? Any advice would be greatly appreciated.
BlueLite
06-28-2001 19:39:42
 Re: How to repair shifter to remove looseness and preving sticking? in reply to John Bailey, 06-26-2001 20:03:14
I had the same problem with my MH. After removing the cover plate that the ball was attached to (which I discovered I didn't have to do), it turned out to be the snap ring that holds
the ball in the socket came loose. I should have
noticed, it was at the bottom of my shift stick
and I thought it was some scrap ring that the previous owner slid over it.
With the cover off, it did give me a chance to study the shift mechanism though.
C. T. Chandler, Jr.
06-28-2001 17:51:43
I am not sure why the previous responses were posted. Maybe he has a personal axe to grind. I would suggest contacting Big Dean, a retired Massey Ferguson mechanic. His web address is:
http://hometown.aol.com/daustin62/Bigdeantipindex.html. C. T.
He definitely knows his stuff!!
06-30-2001 21:02:13
 Re: Re: How to repair shifter to remove looseness and preving sticking? in reply to C. T. Chandler, Jr., 06-28-2001 17:51:43
He gave me the information that I needed. Thanks for pointing me in the right direction.
I don't know
06-28-2001 13:55:29
Take it to a transmission shop
Call the local MF dealer
06-28-2001 13:57:08
 Re: Re: How to repair shifter to remove looseness and preving sticking? in reply to I don't know, 06-28-2001 13:55:29
They would be more than glad to fix it
It doen't have to be just a MF dealer
06-28-2001 13:58:36
 Re: Re: Re: How to repair shifter to remove looseness and preving sticking? in reply to Call the local MF dealer, 06-28-2001 13:57:08
other shops can work on them as well.
