Fuel and oil blowing out dipstick
mr crc
06-25-2001 01:19:02
can this be bad seals in injector or primmer?
Bryan Lunt
06-25-2001 20:36:29
 Re: fuel and oil blowing out dipstick in reply to mr crc, 06-25-2001 01:19:02
You must have compression in the lower block. I would 1st check the breather (side of block-might be plugged up)
2nd run a compression test on all the cylinders. Broken cylinder,piston or worn rings (create "blow by")
3rd make sure that you have not got a valve lifter backed off and not operating the valve. If there is fuel in the oil then the cylinder isnt firing but are you sure its fuel and not water which would indicate a cracked block or head or possibly gasket trouble.
