Adding rear hydraulic lines
Tony Silva
06-24-2001 15:22:17
First a big THANK YOU! to all of the great people on this list that have helped me out. My tractor is running great and all the systems are operating fine.
Now the Question: 1960 mf202 industrial with a loader.
Can I add on the extra hydraulic lines to the rear for certain implements? I would like to get a fence post driver. If these lines can be added, do they hook up to the three point system or to the front loader system?
Thanks for any help
Tony Silva
Lincoln, CA
BlueLite
06-28-2001 15:46:49
 Re: adding rear hydraulic lines in reply to Tony Silva, 06-24-2001 15:22:17
caught your post a little late. You can
use snap on adapters to your current line if you
want to make your 3PH removable, or simply use
"T" sections. Make sure you have a release valve in your 3PH cylinder set for that cylinder's max pressure.
