Difference between MF 35 and MF 135
Gunnar
06-21-2001 01:53:19
Can anyone describe the differences between MF 35 and MF135.
Gunnar
smokey
06-21-2001 17:44:17
 Re: Difference between MF 35 and MF 135 in reply to Gunnar, 06-21-2001 01:53:19
Not much if it is a later model MF35 and a early model MF135. Some MF35 generics were built recently in Europe - may have more features than a MF135.
Early MF35 had the less reliable 4 cylinder diesel motor.
Late MF35 had the 3 cylinder perkins motor.
Early model MF135 have the same bent axle set up as the MF35
The later MF135 have a straight axle and no braces.
Basically look for a 3 cylinder perkins.
A unit with a 2 stage clutch which works properly.
Hydraulics which work smoothly
A diff lock that works - not rusted.
3ptl - MF35 has cat 1 late MF135 may have optional cat 2
- these bits get swapped around a bit depending on use.
Wheel size is another variable - low wheels good for ploughing and may be slashing steeper even ground. Large wheels are good for uneven but not steep ground. depends what you want to use it for.
Gunnar
06-21-2001 21:55:30
 Re: Re: Difference between MF 35 and MF 135 in reply to smokey, 06-21-2001 17:44:17
Thanks, Smokey.
Best regards
Gunnar
