M-H 44 R Special/333/444 Transmission Cases
mick
06-20-2001 18:04:16
I have a 1955 Special w/'Hitch-All', about to tear down finals, for seal, bearings,live clutch
and brake work. This deep, I thought of putting it
all in a 333/444 case, gaining lowered PTO, and
improved center link draft.If I retro a plate for
the Hi/Lo site & handle, modify my 'Hitch-All'
shaft mounts to bolt lower & to the rear, the case
might work. I question if the axle housings,gears,
mounted cylinder will interchange? Any advise,
comments? A wise update or component conflict?
ET
06-21-2001 06:02:21
 Re: M-H 44 R Special/333/444 Transmission Cases in reply to mick, 06-20-2001 18:04:16
My thought on this is if you want a 444 and its goodies then buy one in the long run you are better off than building a tinkermobile. Just my two cents worth good luck with whatever you do.
