MF40-Starter Problems
Greg
06-19-2001 20:09:31
My MF40 engine (Perkins) won't turn over. The starter just humms. I replaced the battery, but this did not solve the problem. I don't know if the engine is "locked up".
Greg
06-20-2001 18:59:30
 Re: MF40-Starter Problems in reply to Greg, 06-19-2001 20:09:31
Thanks for the info. I tried to turn the engine over by putting a wrench on the crank, but it wouldn't budge. When I last shut the engine off it did not make any unusual noises. Could it be a problem with my hydralic pump?
smokey
06-20-2001 16:27:00
Had the same problem on my MF135. luckily had a sparky staying at my place. He pulled the solenoid apart and cleaned it. Only problem is it requires soldering to get it apart and reassemble.
Other problems it could be - crook leads or terminals. Jammed starter gear on ring gear etc.
Does motor turn using fan blade?
