MF 85
Need purchase advice
Dennis
06-18-2001 19:18:08
Looking at a MF 85 diesel that the seller says is in fine mechanical condition. As I am unfamiliar with tractors, was hoping for a little advice. Need a tractor that I can add a loader to and a brushhog for working about 80 acres of pasture. Could use some specs on the 85 (weight, hp, transmission, etc.) and a little experienced advice as to the pluses and minuses of the 85.
Thank you for any help you can give.
Tom from Ontario
06-21-2001 18:39:16
 Re: MF 85 - Need purchase advice in reply to Dennis, 06-18-2001 19:18:08
I used to get 40 gallons of gas a day through mine and one long day, I put 60 gallons through it. High gear on the road is fast enough to be dangerous, make sure the steering is snug and it will turn freely in both directions with no hangups. If you have to tear the steering tower apart, you'll empty your wallet pronto. I got a whole bunch of work out of the one I had, but it was constantly fix, fix, fix and if I had found the tractor I wanted then and have now, I wouldn't have touched the 85. I would however cheerfully buy a 65,165, or a 175. Good Luck whichever way you go.
Jim T
06-19-2001 19:36:42
Dennis, I posted some info on a MF 85 earlier but did not seem to go through. E-mail me at [email protected] and I will get back to you. Jim
Chuck
06-22-2001 08:22:03
 Re: Re: MF 85 - Need purchase advice in reply to Jim T, 06-19-2001 19:36:42
Its a strong tractor 60+ hp but its also a odd
ball.I cant find parts for mine (new or used ones)
Get a real good deal $ on it or pass it up.
