Fuel lines to where on inj pump??? Mf35 Perk Diesel.
gerald
06-16-2001 15:33:25
I just worked my clutch over and tried to start my motor. It will start after I bleed the fuel sys then die a 5 sec later. Tried this a few times. Never had this problem. I got to thinking maybe I have the two fuel lines crossed out of my last filter to the injector pump. My question: Does the fuel in go to the front of the pump or to the back of the pump?? My filter says in and out with arrows but my pump does not. Thanks.
ralph
06-17-2001 02:31:10
 Re: Fuel lines to where on inj pump??? Mf35 Perk Diesel. in reply to gerald, 06-16-2001 15:33:25
Fuel enters the injection pump at the rear. If you remove the large fitting at the rear where the fuel line connects, you should notice a small strainer, ( fuel inlet filter ) and fuel pressure regulator valve.
The front connection is the return line. During operation, extra fuel which is used as coolant and lubricant for pump parts that move is circulated through the pump housing and returned to the filter. There is a check valve in the injecton pump fuel return passage. If the lines, (inlet and outlet), are crossed the engine will only run for as few seconds after priming the system because of the check valve.
The small filter on the inlet line is not sold my most Massey Ferguson dealers. I have seen mechanic trying to increase the fuel pressure by shimming the spring on the pressure regulator valve. The gasket material used on the injector pump will not support this increase fuel pressure.
Hope this information helps. Massey Ferguson and other companies that use Perkins engines don't explain this in their manuals.
Good luck!!!!! ! Ralph
