Difference between Massey 20 and 22???
Irv Plitzuweit
06-15-2001 07:04:16
Thought I had a Massey Harris 22 but when putting rings in it it has 3 inch pistions not 3 3/16 like 140 ci Massey 22 has. On careful inspection the serial plate says 20GR 4040, which I think is a 1948 model. Its no big deal, but what really is the difference except for the engine 124 ci to 140ci. Thanks for any info. Irv
Tom E
07-01-2001 06:21:32
 Re: Difference between Massey 20 and 22??? in reply to Irv Plitzuweit, 06-15-2001 07:04:16
The grill on the #20 is louvered like the earlier #81. The grill on the #22 is the same style as the #30,44 and 55 tractors. Also the brakes are different between the two except for the very early #22's.
Alberta Mike
06-15-2001 11:01:23
I would think that's about it. The 'G' in your serial number indicates it is a gas model and the 'R' says it is a rowcrop (narrow front, adjustable rear wheels) version. Nice little tractors and easy to work on and repair.
Eric
06-19-2001 20:05:44
 Re: Re: Difference between Massey 20 and 22??? in reply to Alberta Mike, 06-15-2001 11:01:23
The rear tire size aren't the same and there is a difference in sheet metal.
