MF 65 power steering
Keith
06-14-2001 07:24:29
I just bought a MF 65 LP and the power steering fluid keeps leaving (quickly) as the oil level in the crank case rises! Coincidence? I think not. Being a Minneapolis Moline and Deere owner for years this is my first Massey tractor. What is the most probable path the fluid is transferring? The resevoir for the steering is right over the crank case fill and I am hoping this is a gasket...not a crack. Looking forward to meeting some good Massey folks. Sure have met fine people from the other colors.
Pat
06-16-2001 17:48:13
 Re: MF 65 power steering in reply to Keith, 06-14-2001 07:24:29
The power steering pump is driven directly off the timing gear train on the gasoline models (I believe the LP is the same engine modified for LP), so my best guess is that the seal on the pump shaft is leaking. If this seal is gone, the fluid would drain directly into the crankcase.
