MF65 timing
Doug
06-11-2001 14:48:37
My MF65 (with G176 Continental gas engine) backfires when under load, or when applying power quickly. In this condition, it won't develop any power. I assume it is the timing. Does anyone know how to set the timing on this tractor? There do not appear to be any external timing marks. Or do you have any other guesses as to the cause of the problem?
kyle
06-14-2001 10:33:07
 Re: MF65 timing in reply to Doug, 06-11-2001 14:48:37
I have the same tractor and this problem started.
I had hole burnt in the rotor button. I replaced it and have not had a problem yet.
jim
06-12-2001 12:01:06
did you check the gap on the points.this could be the problem
Doug
06-13-2001 07:25:10
 Re: Re: MF65 timing in reply to jim, 06-12-2001 12:01:06
I replaced the wires, distributor cap, rotor and condensor. I replaced and gapped the points and plugs. I regapped the tappet clearance. I totally cleaned and adjusted the carb. Now, with advice from this discussion group, I have adjusted the timing. However, it still backfires when under load and has no power. It also still stalls when the throttle is advanced quickly. Any suggestions?
Cal S
06-11-2001 17:32:55
Doug, On the dipstick side of your engine on the bell that fastens to the trans, you will find a round plug at the same level as the dip stick hole. Pry the plug out and your timing marks are behind the plug on the flywheel. no one cyl should fire at 6 degrees btdc. Cal S.
Jim/Mississippi
06-11-2001 18:19:16
 Re: Re: MF65 timing in reply to Cal S, 06-11-2001 17:32:55
Cal is right and something else to mention. The flywheel most probably is a bit rusty and to see the marks you will need to put some light on the subject . Have an assistant turn the engine very slowly and when you have positioned the flywheel so the timing mark is viewable in the center of the view hole, take some white paint on a toothpick to mark the spot on the flywheel so that it will show when using the timing light . :>)
David Geluz
02-10-2002 06:11:14
 Re: Re: Re: MF65 timing in reply to Jim/Mississippi, 06-11-2001 18:19:16
I did the dumb mistake of removing my distributer before i was sure I had marked it. I dont know where the timing mark view hole is on my MH-50. Is it through a hole in the frame? Will the hole have degree marks? How big is the view hole?
