Distributor Parts for MF-202
Larry Dozier
06-11-2001 14:46:14
Help. I need to locate a dealer or other parts source for distributor cap, rotor and dust cover for MF-202 with Continental engine. Specifically, the dust cover is missing, and the cap doesn't fit tight without it.
Years ago, there was a place near Norwich, CT called Tractor Parts Unlimited that had parts, but I can't seem to locate them.
Any suggestions for parts source?
A shop manual says Delco-Remy distributor model 1112557, 1112570 and 1112585 were used. Are there any distinguishing characteristics to help me determine what was used on MF-202?
Any help would be appreciated. Thanks.
Signed,
Stuck in the Woods in RI
paul
02-10-2002 16:10:40
 Re: Distributor Parts for MF-202 in reply to Larry Dozier, 06-11-2001 14:46:14
i am looking for parts for a allis chalmers d15 dozier ( chains )- for tracks.if you don't have them could you direct me to someone that has them,i would really appreciate it. thank you.
kevin shuler
06-20-2001 19:15:44
try these folk's A&A Tractor salvage westfork arkansas 501 839 8189
Larry Dozier
06-26-2001 15:59:15
 Re: Re: Distributor Parts for MF-202 in reply to kevin shuler, 06-20-2001 19:15:44
Have found the parts at NAPA. They were able to cross-reference, and the following part numbers work just fine:
Cap: RR145
Dust Cover: RR164
Rotor: RR83
Points: CS763P
Now that I have more time, I'll check out other sources. Thanks for your help.
Larry Dozier
