MF 2775 ring/pinion question
John in SD
06-06-2001 19:39:00
I have my 2775 torn down in the dealer's shop to change a cracked rear end casting. All of the disassembled parts look good except for the pinion gear which has 2 or 3 teeth scuffed up. The ring gear looks fine. The dealer is going to check salvage yards for a used ring/pinion set. I may also do some checking on my own and would appreciate any leads you guys may have. My question is, why do I have to change both the ring and pinion as a matched set? Why can't I get just a new or used pinion gear to use with my good ring gear? Don't they have to adjust clearances with shims anyway? BTW, new price is ... are you sitting down? ... $2500!!!
marlowe
06-07-2001 15:12:38
 Re: MF 2775 ring/pinion question in reply to John in SD, 06-06-2001 19:39:00
when i worked for massey we some times would not replace both but this was on low HP tractors and only at the requst of the owner but on the big HP stuff i don't think i would do it just becasue of the labor cost and what the damage might do to other stuff call 1-920-984-3327 i think they have a burnt one good luck
John in SD
06-07-2001 17:34:37
 Re: Re: MF 2775 ring/pinion question in reply to marlowe, 06-07-2001 15:12:38
The dealer found a new ring/pinion set and ordered it from another dealer. Not going to cost as much as ordering from the factory, only a couple hundred more than used. Yes, I told the guys that we only want to get into this thing once so do it right. I hope after they get done with it that it will outlast me and it should.
John in SD
06-07-2001 17:30:33
