Massey Fergison 65 power steering
Dennis DeVore
06-06-2001 09:44:56
I have a MF-65 with a front loader. The power steering does not seem to be working. Even when I remove the bucket from the front loader the tractor is very hard to steer. Anyone that has information about the power steering and could help I would appreciate.
Jack in NB
06-08-2001 09:11:54
 Re: Massey Fergison 65 power steering in reply to Dennis DeVore, 06-06-2001 09:44:56
Gentlemen -
There's a common problem with 65 and similar power steering systems - linkage wear.
Assuming fluid levels are ok, and the pump is putting out, check the pins on each end of the adjustment turnbuckle up front connecting one of the main castings to the control valve on the top of the cylinder.
1/64" movement in that control valve makes the difference between operating and not operating. The pins and holes on each end of the turnbuckle seldom if ever get oiled, and after 40 years.....
they wear!
Have someone else operate the steering wheel in both directions and check to see that the control valve follows the casting movement. 1/16" spool movement in each direction is good. If you haven't got that, you may have isolated the problem.
With the grill off, tractor idling, (wheels blocked so you don't wind up in hospital!) have your trusty assistant crank the wheel to move the spool into the valve body, and pry the valve spool in further with a big screwdriver or pry bar to see if you get hydraulic steering response. Be careful not to punch the rad... This will tell you if the pump is putting out.
Hope this helps.
Randy Cornelius
06-07-2001 04:22:14
To fill the fluid level, find the pump located on the left side of the engine. Unscrew the cap located to the rear of the pump, it should take a 5/8 wrench. Use any good type auto transmission fluid. Fill to top. start engine and turn both ways several times to get the air out. Stop engine and re check and fill to top of full hole. If this does not work you will need to replace pump or check for other problem.
good luck
davis d
06-07-2001 00:14:30
Have you checked the fluid. My MF manual says to fill with the motor running. Turn the steering wheel from one side to the other completely, all the way till it stops, both ways. This will cycle the air out of the system. Do this several times. Do this with the cap off. Recheck the fluid.
This is for a MF 40 it could be different on the 65. Good Luck.
