Steering on MF 65
Randy Cornelius
06-05-2001 18:57:36
I just bought a late model #65 MF Diesel tractor. The steering has a problem, it will crank all the way to the left and turn very tight to the left but not to the right. It will only turn about 1/2 the distance that it will to the left. It seems like it hits on something but visual inspection does not show it hitting on anything.
Does anyone have any ideas. I'm sure there is some type of adjustment there but I have not been able to figue it out.
Randy
rod
06-05-2001 19:33:10
 Re: steering on MF 65 in reply to Randy Cornelius, 06-05-2001 18:57:36
I would try to isolate the problem by removing tierods and trying the steering this will rule out the spindles then just keep unhooking until it all works. Hope you understand once unhooked will the steering wheel turn ok if so steering box is ok, keep working through it often parts get bent and will not work correctly.
regards
rod
